1999 Chevy S-10 Fuel Pressure drops afer priming
100,242 MILES • 4 CYL • 2WD • MANUAL
LTAPPER
I have a 1999 GM S-10 with the 2.2L MFI fuel injection. It does not start right away but turns over several time before it starts. I checked the fuel pressure and found the when the ignition key is turned to auxillary position the fuel pump runs the prime cycle and the fuel pressure goes up to 55psi but when the pump prime cycle stops the fuel pressure drop back to zero almost immediately. When the engine is started the fuel pressure with the engine idling the fuel pressure is 35 psi and then when the vacuum line is pulled off the fuel pressure regulator the pressure goes up to 42 psi. When the vacuum line is replaced the pressure returns to 35 psi. Is there something wrong with the fuel pump or a check valve on the fuel pump that would require it to be replaced. Is this something that can be lived with?
Thanks,
Oct 28, 2008 at 2:15 PM
  • 75,988 POSTS
Hi ltapper and welcome to 2carpros
If pressure drops quickly, the vehicle may have a leaky fuel line, a leaky fuel pump check valve, a leaky fuel pressure regulator or one or more leaky fuel injectors.
Oct 28, 2008 at 2:37 PM
