Changing transmission fluid
TRUEFIRE04
  • 35 POSTS
The solinoids are cheep anuff to replace booth of them at the same time and wile your in there replace the filter too. Was the code fore bank sensor 1- 2 or 3. If its a down stream sensor 3 the 02 sensor might be bad, dose the exhaust smell like rotting eggs? If not it could be the 02 sensor
Monday, December 9th, 2019 AT 9:49 AM (Merged)
BENMASHLIN
  • CHEVROLET S-10
I have a 1993 chevy blazer, 4.3 L vortec engine with electronic 4wd and 200,000miles. My transmission went out and I replaced with another one from a blazer with 70,000miles and also adjusted the shift linkage but after spending all that money the truck wont move at all, all fluids levels are good and am wondering what could be wrong with it? Whats the work of the throttle valve on the transmission?
Monday, December 9th, 2019 AT 9:50 AM (Merged)
POET042005
  • 134 POSTS
Hi Ben first off do you no the history of the truck you received the new transsmision from. Second when the transmission went out what happened, did it go all at once or did you have signs of on coming failure. Example a possible noise before it went did the truck jurk or was the trans slipping in one or more of the gears. We have to find out if your having actual trans problems or not.
Let me no
Richard
https://www.2carpros.com/forum/automotive_pictures/15504_me_just_fa_1.jpg
POET042005
  • 134 POSTS
Let me no
Richard
