1997 Chevy S-10 Won't start
2STIX
  • 1997 CHEVROLET S-10
  • 6 CYL
  • 141,000 MILES
I have a '97 Chevy S-10 with 141,000 miles. I have tried to start the truck today and it will not start. The battery had the power to turn it over, but the truck will not fire. It started just fine all day yesterday. What things should I look at?
Sunday, November 23rd, 2008 AT 11:48 AM
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, November 23rd, 2008 AT 11:56 AM
