1997 Chevy S-10 starts by itself
GREG39
  • 1997 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 150,000 MILES
I was in the house and heard car starting went outside and my 97 s10 blazer was was trying to start by its self the key was still in the off position but the engine was turning over had to take battery cable off and when I put it back on it still trys to start thought it might be the solenoid switch but when I changed it it didnt help put battery cable back on and still turning over could it be the ignition switch please help im lost here
Sunday, September 7th, 2008 AT 3:26 PM
You sure its not a ghost? Okay if you have a remote start have it checked out to include the ignition switch.
Sunday, September 7th, 2008 AT 3:40 PM
GREG39
  • 5 POSTS
No remote start and I unpluged the ignition switch and when I hook battery cable back up it still turns over
Sunday, September 7th, 2008 AT 4:34 PM
Inspect the battery cable/terminal at the starter could be grounding out on the starter solenoid.
Sunday, September 7th, 2008 AT 4:43 PM
GREG39
  • 5 POSTS
Nope it wasnt battery cable
Sunday, September 7th, 2008 AT 5:09 PM
Disconnect the battery and then find the ignition switch connector-disconnect it-hook up battery is it cranking the engine over?
Sunday, September 7th, 2008 AT 5:17 PM
GREG39
  • 5 POSTS
Yes it still turns over when I hook cable back up
Sunday, September 7th, 2008 AT 5:27 PM
Better double check the starter solenoid if its sticking closed it 'll do that.
Sunday, September 7th, 2008 AT 8:27 PM
