1996 Chevy S-10 will not start
TAMMYDONELL
  • 1996 CHEVROLET S-10
Engine Performance problem
1996 Chevy S-10 6 cyl Four Wheel Drive Automatic
new coil, getting good fire, fuel system has good pressure, cranks good, just will not start
Tuesday, February 16th, 2010 AT 7:09 PM
Compression:
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Tuesday, February 16th, 2010 AT 7:16 PM
