Hello, there should be a fuel pump prime connector under the hood. It is a test circuit for the pump, you don't use the key. The connector should be on the same side of engine compartment as the battery, hopefuly close to the battery. I don't have the exact location. The wire could be gray or red, should be in plain site, the wire has an electrical connector, nothing plugged into it. If you use a jumper wire with inline fuse and run voltage to that connector, the pump should run and you can check fuel pressure.
SPONSORED LINKS
Monday, August 24th, 2009 AT 11:02 AM
