Have changed the distributor, cap, rotor. Coil, module, and crank position sensor but still will not fire. Also when checking to see if the crank sensor had fire going to it I touched test light to the three wires and one had fire going to it and one of the other wires on the sensor the fuel pump came on the IAC valve started making noise and it blew back through the carb.
Thanks O
SPONSORED LINKS
Thursday, April 10th, 2008 AT 8:50 PM
