Engine turns over but won't start, fuel pump is working but the instrument gauges are not.
Also I can not get the transmission shifter out of the park position. Key is on and foot on the break.
Thanks Dale
Saturday, August 23rd, 2008 AT 8:34 AM
MECHANIC
Engine turns over but won't start, fuel pump is working. It might be working is it producing the correct fuel pressure-you need to check it.
Lock in park-are the brake lights working? If so test the shift lock solenoid.
