1995 Chevy S-10 starting problem
4DENISUE
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 175,000 MILES
: ? Can popping clutch/push starting a stick shift cause teeth in flywheel to break? Some years ago a person I trust had said this but another mechanic says this is not possible? Please if you KNOW would you settle this :| Thank You! :
Friday, March 21st, 2008 AT 9:11 PM
BLACKOP555
  • 10,371 POSTS
Not its not going to do anything to the flywheel, flywheel is used for starting only with the starter, if you pop the clutch there is nothing that can affect the flywheel unless you try to turn the ignition to the start position as your popping the clutch.
The owners manual on some suggest push starting it if the battery is dead.
Saturday, March 22nd, 2008 AT 7:03 AM
