1995 Chevy S-10 starting
BIGVERN13
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 210,000 MILES
Truck ran fine, never had a problem. Then parked it, went to try to start it 2 minutes later and it is dead. Nothing. Wont crank, no click, nothing. Has good starter, good battery, good gages, lights, radio, etc. Any ideas what it could be or what I should check?
Thursday, January 7th, 2010 AT 5:14 PM
Double check battery connection and at starter side-if okay-Hold key at start position and check for power at the starter solenoid purple wire if none -check and test the park/neutral switch and the ignition switch.
Also check if the alternator is putting out-
Thursday, January 7th, 2010 AT 5:30 PM
