1995 Chevy S-10 95 S-10 Blazer wont start
JABAJABA
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 175,000 MILES
My blazer will not start unless you spray starting fluid of place gas into intake then it starts fine and runs fine after it starts if it runs for a while(15-20 min) you turn it if and start it again it usually starts right back up. Seems like not enough pressur to start from cold how do I check for pressure and what can I do to fix this problem thanks in advance for your help!
Monday, August 18th, 2008 AT 7:22 PM
BLACKOP555
  • 10,371 POSTS
Well you will need a fuel pressure tester, ask around to see if its compatable for your vehicle. Then with it hooked up turn they key on, does pressure go up to specs and hold/ should hold within 5 lbs of the specified pressure for 1 minute after key is off. Post back what you find.
Monday, August 18th, 2008 AT 10:22 PM
