1993 Chevy S-10 Truck wont start
FIRECOP77
  • 1993 CHEVROLET S-10
  • 6 CYL
  • 26,800 MILES
Even with gas in the intake truck wont fire just turns over. How do I test coil? Anything else I should check?
Saturday, January 31st, 2009 AT 8:55 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/how_to/how_to_tune_up.htm
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Saturday, January 31st, 2009 AT 9:07 AM
