'93 S10 / starts then stalls then wont start
GOG8TRZ
I have a 1993 chevy S10 4.3 V6 2wd.
Most of the time i try to crank it up it wont start (turns over good), but when it does start it stalls within 30 secs or so.. I will come and try to start again later in the day and the same thing would happen..
Could this be something as lil as a fuel filter???? or is it more the likely the fuel pump?? of course im assuming it is a fuel problem..
**update** upon further inspection the fuel pump is turning on, i hear it turning on when i turn on the key
May 1, 2007 at 8:35 AM
GOG8TRZ
started up fine today drove it to work and when i went to leave work started then stalled about a block from work and had a friend tow me home...
hope this is helpful..
Could this possibly be my fuel pump??
any help would be appreciated..if you need more info just drop a line.. im clueless when it comes to trucks
May 4, 2007 at 7:14 PM
E90SUPRAT
Read my post titled 93 s10 blazer 4.3(w)starting issues. While the problems I was having are different from yours, the answer the tech gave me may be of some use to you. Hope this helps.
Ed
May 5, 2007 at 1:57 PM
