Truck will not start. Sounds like it wants to but wont. As soon as you spray starter fluid in the carburator the truck starts right up and runs fine.
i drove it 174 miles with it like this. What could it be?
Friday, January 9th, 2009 AT 5:55 PM
DE772601
MEMBER
Hello well this sound like a fuel pump going bad first check to see what kind of fuel presure you have if it only around 10psi or so then you have a bad pump. I hopr this will get you where you need to be.
