89 S-10 will not start
HAZ_R_DOUS1
  • 1989 CHEVROLET S-10
Hi I have a 1989 s10 with a 2.5. I have had since brand new. Here is the prob, it will not turn over but you can push start it. New alt new starter and battery. It will not even turn over when you bypass the starter with a screwdriver. Please help
Haz
Friday, January 6th, 2006 AT 11:52 AM
SMOKINFLOYD4.3
  • 56 POSTS
Your starter bendix is probally in a bind with the flywheel, or. Is there any power getting to your starter?
Friday, January 6th, 2006 AT 12:35 PM
HAZ_R_DOUS1
  • 6 POSTS
The bendix isnt hung up I checked that, I forgot to say that when you turn the key all you hear is a click. Lights, radio, and everything works fine. It just will not turn over but will run if push started.
Thank you for your reply
Haz
Friday, January 6th, 2006 AT 2:32 PM
HAZ_R_DOUS1
  • 6 POSTS
Ok found out that it was the starter and the O2 sensor all is well except for it idles real rough no codes are coming up on the machine or with the jumper wire and other things I need to check.
Thanks Haz
Sunday, January 8th, 2006 AT 11:39 AM
