1987 Chevy S-10 weird noise
GBIRDSALL
  • 1987 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • MANUAL
  • 168,492 MILES
I have just replaced the transmission on my s-10 from the automatic that was in it to a 4 speed everything fits right the clutch is bled and the vacume lines are connected once everything was together I tried to start the truck at which time a loud noise came from the truck it dosent happen when the motor is trying to start only when the motor starts and is running and it dose not go away all the fluids are up in both the transfer case and the transmission the sound still occurs with clutch disengaged or engaged so I know its not the throw out bering or the input shaft
Monday, December 1st, 2008 AT 11:35 PM
DOCFIXIT
  • 18,828 POSTS
Is starter hanging up? Flywheel hitting?
Tuesday, December 2nd, 2008 AT 10:24 AM
GBIRDSALL
The only thing I can think of is the vendix assembily on the starter is not releasing but I have shimmed it to all ends to the point where it no longer has contact and then removing a shim to where it will start the truck and the noise is still there
Tuesday, December 2nd, 2008 AT 11:15 PM
DOCFIXIT
  • 18,828 POSTS
Jack it up get a long screw driver run truck use driver to find noise. Ie. Place handle to ear tip to bell housing, pan ect.
Wednesday, December 3rd, 2008 AT 7:27 AM
GBIRDSALL
Dont want to run the truck long enough to let what ever this is really damage it so its hard to locate this noise without taking a huge risk any other ideas?
Friday, December 5th, 2008 AT 8:41 PM
DOCFIXIT
  • 18,828 POSTS
You got to break a few eggs to make an omlet. Can't find noise if it's not making it
Saturday, December 6th, 2008 AT 9:50 AM
