One day it would spin but not crank. The engine rotated sounded a little faster than normal. Eventually it made a slight attempt to run and then quickly stalled. I disconnected the wire under the dash that you disconnect when you set the timing. After a few tries it ran, and I quickly attempted to make it home. Almost got home and then it died. It is home now, but the engine will turn over (like faster and eventually it will try to crank, but then quickly die). Here is what I have changed:
The pick up coil, ignition module, rotor and distributor, fuel pump.
Before I disconnected the computer, I got a code about the spark control module.
It is getting plenty of gas, and fire. I have tried to reset the timing, and it seems right on, but like before it will not run.
Any ideas?
Sincerely Brian
SPONSORED LINKS
Thursday, May 20th, 2010 AT 12:57 PM
