1987 Chevy S-10
LONGLINEGIRL
  • 1987 CHEVROLET S-10
1987 Chevy S-10 4 cyl Two Wheel Drive Manual
will crank but will not fire. All of a suden died going down the road. Then cranked and fired on more time. Sat and idles for 5 minutes. Opened the door and sat down and it died again and will not fire back up but wll crank
Tuesday, December 23rd, 2008 AT 4:33 PM
Do below to determine if its fuel or spark issue then tell me what happened
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tuesday, December 23rd, 2008 AT 6:04 PM
