how do i remove the rear spark plugs on a 2002 chevy venture 3.4 liter van please help me
Aug 22, 2006 at 4:20 PM
To service the rear spark plugs, put the van in neutral and rotate the engine after removing both left and right engine mount strut brackets. Use the second hole in one mount to hold the engine with a bolt. You may also need to remove the wiper module cover.
The owner asked how to remove the rear spark plugs on a 2002 Chevy Venture with a 3.4L engine. The expert said the engine must be rotated for access, which requires removing both engine mount strut brackets, shifting to neutral, and securing the engine with a bolt in a second mount hole. The wiper module cover may also need to be removed.
