2002 Chevy Venture Rear Spark Plugs
CHEVROLET
UNCLEWOOTSIE
  • 40 POSTS
how do i remove the rear spark plugs on a 2002 chevy venture 3.4 liter van please help me
Aug 22, 2006 at 4:20 PM
MIKEYBDMAN
  • 623 POSTS
[quote:65bac37092="unclewootsie"]how do i remove the rear spark plugs on a 2002 chevy venture 3.4 liter van please help me[/quote:65bac37092]
You will need to rotate the engine to service the rear plugs. You also may need to remove the wiper module cover.
To rotate the engine, you will need to remove both left and right engine mount strut brackets. THere should be a second hole in one of the mounts to rotate the engine and insert the bolt to hold. You will need to place the van in neutral to rotate.
Aug 23, 2006 at 12:05 PM
Suggested Repair
To service the rear spark plugs, put the van in neutral and rotate the engine after removing both left and right engine mount strut brackets. Use the second hole in one mount to hold the engine with a bolt. You may also need to remove the wiper module cover.
Conversation Summary
The owner asked how to remove the rear spark plugs on a 2002 Chevy Venture with a 3.4L engine. The expert said the engine must be rotated for access, which requires removing both engine mount strut brackets, shifting to neutral, and securing the engine with a bolt in a second mount hole. The wiper module cover may also need to be removed.
