2001 Chevrolet Impala Temp Gauge Failure
CHEVROLET
AM544
Hello, I have a 2001 Chevrolet Impala 3.4 Liter with 80,000 miles. The check engine light came on and the temperature gauge stopped working. The code said that there was a problem with the temp. sensor. I replaced the sensor and the check engine light turned off and the gauge started working. Two days later the check engine light came on and temp gauge stopped working again. I repeated the process of changing the temperature sensor and gauge still doesn't work. Can somebody please help me??? Thanks
Jan 26, 2007 at 8:27 AM
BUBBA_KOSKI
  • 129 POSTS
ok when you changed your temp. sensor, the plug-in that plugs into the sensor has short circuited, happens alot on chevy's, take a meter to her first before you take any steps to fix.
Jan 26, 2007 at 11:29 AM
CPT87GN
  • 8 POSTS
did you do what he said did it work i have the same car and problem
Oct 15, 2007 at 3:01 PM
Suggested Repair
Before replacing the temperature sensor again, test the sensor connector and its wiring with a multimeter for a short. On these Chevrolets the plug that connects to the sensor often shorts and can make the gauge and check-engine light fail again.
Conversation Summary
The owner of a 2001 Chevrolet Impala 3.4L said the check engine light came on and the temperature gauge stopped working with a temperature-sensor code. Replacing the sensor restored both briefly, but the problem returned after another sensor was installed. An expert said the sensor connector often shorts on Chevrolets and advised testing it with a meter before further repairs. Another owner asked whether that worked, but no result was reported.
