Chevrolet Impala Overheating
95LEGEND
Need help...
Just replaced my radiator 4 days ago due to the infamous crack at the top(radiatorexpress.com) thanks for the info in previous posts.......didn't replace the thermostat because 3 places didn't have them in stock the morning that i replaced it but i plan to this weekend....Drove from charlotte to atlanta and back (3.5 hours each way without any issues.....Here is the problem that i'm now having...
The second day with the new radiator...the temp gauge went up to the "hot" level then immediately went back down before i could pull over....the rest of the day it didn't happen again...The third day it happened again....then went back down.....The fourth day it happened but didn't go back down immediately...so i pulled over and raised the hood thinking i may see or smell smoke or the engine would feel overheated...but none of this..no smoke or smell, engine still felt cool...this happened after 10-15 minutes of driving after leaving work...i get back in the car and start it up and the temp gauge is where it should be so i drive home (another 15 minutes and no problem with temp gauge)...fifth day same thing on the way to work...when leaving work...i check under the hood and the upper radiator hose is colapsed inward...i remove the radiator cap and it seems like it released a lot of pressure when the cap was removed....tightened the cap and proceeded to drive home (only a 15-20 minute drive) and the temp gauge rises again but doesn't go back down immediately so i pull over and wait about 5 minutes..start the car and it stays where it should the rest of the way home....
If the cooling system needs the air bleeded out how long should this take and when will i know that the bleeding process is complete...
I'm going to change the thermostat on saturday..could this be the problem? I read something about the radiator cap....which is the same cap from the cracked radiator because the radiator from radiator express didn't come with a cap....but if it fits tightly and secure does it still need to be replaced?
Jan 5, 2006 at 7:30 AM
95LEGEND
Also replaced the upper and lower radiator hoses with the new radiator and there both warm after driving....i'm hopiing the thermostat replacement fixes it.
Jan 5, 2006 at 7:33 AM
JOSEF
  • 6 POSTS
after driving your upper radiator hose should be kinda hot if its not your thermostat needs to be changed and getting the air bubbles out you just squeese the upper radiator hose and release slowly and watch the coolant bubble up, when you see no more bubbles your gravey.
Jan 11, 2006 at 7:02 AM
2CARPRO JACK
  • 11,533 POSTS
dont forget to replace the radiator cap
Jan 24, 2006 at 9:26 AM
TCBUCKHORN
Did the new thermostat or radiator cap fix the problem?
Jan 24, 2006 at 9:39 AM
Suggested Repair
Replace the radiator cap. The cap from the old radiator was reused and may not be regulating pressure correctly, which fits the collapsed upper hose and intermittent high temperature-gauge readings.
Conversation Summary
A Legend owner replaced a cracked radiator and both radiator hoses but reused the old radiator cap and had not yet replaced the thermostat. After an uneventful long trip, the temperature gauge intermittently rose to hot and sometimes stayed high, although the engine did not feel overheated and there was no smoke or smell. The upper hose was found collapsed, and removing the cap released substantial pressure. The owner asked about bleeding air, whether the thermostat could be at fault, and whether the old cap should be replaced. Another participant said the upper hose should be hot after driving or the thermostat needs replacement, and described squeezing the hose to bleed air until bubbles stop. The expert advised replacing the radiator cap. A later question about whether the thermostat or cap fixed the problem received no reported outcome.
