1988 Acura Legend Overheating
NICKJA87
1988 Acura Legend; about 3 months ago my engine was over heating. I changed the heat sensor and it ran fine. now the same problem is back, the car over heats every time I drive it, the fans never come on. I keep my coolant and oil on full so I hope I have not hurt the engine. is there any way to fix this problem or perhaps to bypass the thermostat sensor?
Jan 3, 2006 at 9:21 AM
JEREMIAH
  • 217 POSTS
i would start with the fans that never comes on.
Jan 7, 2006 at 11:35 AM
JOSEF
  • 6 POSTS
i garuntee my civic has had worse overheating problems than your car and its almost got 400 000 miles on it now. when i had problems i changed my relay switch, or if you are ghetto enough you can rig up a toggle switch to turn on your fan when you wanna
Jan 11, 2006 at 6:54 AM
Suggested Repair
Start diagnosis with the cooling fans that never come on, and check fan operation and the fan relay before considering other cooling-system parts.
Conversation Summary
The owner of a 1988 Acura Legend reported recurring overheating after replacing a heat sensor about three months earlier. The cooling fans do not come on, while coolant and oil levels are full, and the owner asked about a repair or bypassing the thermostat sensor. The expert advised starting with the fans that never come on. Another user suggested checking the fan relay based on personal experience and mentioned an improvised manual fan switch.
