1993 Acura Legend Overheating
1993 HONDA
TROYZZZ2003
i have a 1993 acura legend that is somewhat overheating, i've changed the thermostat the guage is reading normal but it overheating and coming out of the overflow tank. everything seems to be o.k. i've had the car for about three weeks and when i first got it the system was full of air and when i blead it off it seemed to run fine and now it's doing it again it's also getting a little warmer outside so i was wondering do you thing i just need to bleed the system again or do you think it's something more serious?
May 24, 2006 at 1:30 AM
BRUCE HUNT
  • 3,754 POSTS
You definetly need to be sure that the air is completely out of the system. I believe there are a couple of bleeders. Make sure that the fans both operate.
May 24, 2006 at 8:25 AM
Suggested Repair
Fully bleed all air from the cooling system using the bleeders, and verify that both cooling fans operate.
Conversation Summary
The owner of a 1993 Acura Legend reports intermittent overheating, with coolant coming out of the overflow tank despite a replaced thermostat and a normal gauge reading. The system contained air when purchased and improved after bleeding, but the problem returned as the weather warmed. The expert advises making sure all air is removed through the bleeders and confirming that both cooling fans operate.
