1992 Other Honda Models overheating problem
1992 HONDA
DHUPS.GOSWAMI
Engine Performance problem
1992 Other Honda Models Automatic 17000 miles
has overheating problem. NOT HEAD GASKET! It doesn't take long to start over heating. Mechanic says it has water leak under intake manifold and needs to be removed to repair
IS it repairable ... and if yes how much it cost..
As i am thinking to buy purchase honda legend 1992 has 262000 kms runs..
SO asking this question ....
Jan 25, 2010 at 10:06 PM
HMAC300
  • 48,601 POSTS
there cold be a plug or the intake gasket itself is leaking. If the plug is removable then it should be repairable.but the mechanicn should have given you an estimate as costs vary by where you are. I would imagine at least a couple hundred dollars.but it could be more.
Jul 12, 2010 at 6:44 PM
