1991 Acura Legend Overheating
HONDA
ACIDBURN3006
[b:878c521d56]On my [i:878c521d56]1991 Acura Legend[/i:878c521d56] engine starts to overheating after I ride it for awhile. I changed thermostat, temp computer sensor, radiator. The only way I prevent engine from total overheating is by turning A/C on. This way my fans (under hood) turn on and let coolent circulate better. I thought it's headgasket so I added speacial healing solution to fix any leaks. I even tried to take out thermostat and it still overheats but not that much. Some say it's problem somewhere in computer/electricity. Others say it's headgasket. Now I'm thinking of making custom button for radiator fans. What should I do?[/b:878c521d56][/b]
Apr 29, 2006 at 8:09 AM
BRUCE HUNT
  • 3,754 POSTS
Have you checked the sensor that turns on the fan. I know the system will turn on the fans with the air, but they should kick on by themselves when the system gets hot.
Apr 29, 2006 at 12:04 PM
Suggested Repair
Check the radiator fan temperature sensor or switch. The fans should turn on by themselves when the engine gets hot, not only when the A/C is switched on.
Conversation Summary
The owner of a 1991 Acura Legend says the engine overheats after driving for a while despite replacing the thermostat, temperature sensor, and radiator. The fans cool it only when the A/C is turned on, and removing the thermostat only reduced the overheating. The expert advises checking the sensor that should turn the fans on automatically when the system gets hot.
