Thanks,
If the broken key is just inside the ignition, try extracting it with two sewing needles used as prybars, a strong magnet, or duct tape pressed onto the key. If the truck can still be started and locked, replacement may not be necessary. If extraction fails, ignition lock or switch replacement was discussed, but it requires a steering-wheel puller and a special column tool and can damage the column if done carelessly.
The owner of a 1992 Chevrolet C1500 with 189,000 miles broke a key off in the ignition and could not remove it, asking how to replace the ignition. One reply suggested gluing the remaining key piece to the broken tip, which had not worked for that person. Others said the ignition switch or lock would need replacement, either by pulling the steering wheel and using a special tool to release the column clip, or by using a slide hammer to pop out the lock. An expert suggested trying sewing needles, a strong magnet, or duct tape first, and said replacement may be unnecessary if the truck can still be started and locked.
