1991 Nissan Key Broken in Door Lock Fix
NISSAN
GILBIGIN
1991 nissan four door corrisca...
the key broke off in the door.. door is locked.. can't open door (obviously).. how do i extract the broken off key?
Mar 28, 2006 at 1:54 AM
LOSONE
  • 1,616 POSTS
There is no easy way except see a certified locksmith. Sorry about the problem. I have drilled out a few using a micro drill bit but you have to know what you are doing. Good Luck
Mar 30, 2006 at 2:32 AM
Suggested Repair
Have a certified locksmith extract the broken key from the locked door. Drilling the lock with a micro drill bit is possible only for someone experienced and is not a recommended DIY fix.
Conversation Summary
The owner of a 1991 Nissan four-door said the key broke off in the locked door and asked how to remove it. The expert said there is no easy method and recommended a certified locksmith, noting that drilling the lock with a micro drill bit requires knowing what you are doing.
