1996 Chevrolet Cavalier Coolant Leak
CHEVROLET
JPW7184
i have a leak coming from the passenger side of my 96 cavalier. its right under where the collant tank is but it is a orange-red color. the coolant light is on even though the tank is full. is it a bad thermostat or something else like the transmission?
Dec 31, 2006 at 3:25 AM
SERVICE WRITER
  • 9,123 POSTS
For that year car, the color of the coolant sounds right. Need to look closely or drop it off at a garage for pressure testing.
Jan 1, 2007 at 1:35 PM
JPW7184
but the coolant color that i have in there is greenish, should i drain it and put a different type in?
Jan 2, 2007 at 9:13 PM
SERVICE WRITER
  • 9,123 POSTS
Originally the car came with dex-cool which is a 5-yr/150,000 mile coolant. The green is a 2yr/24,000 mile coolant. Mixing them will reduce it's value down to the least common denominator which is the green. I would stay with the green at this point.
I'm not sure what else would have an orange color to it. :? Trans fluid is red.
If the only other symptom is a the low coolant light is on, it is highly likley the sensor for low coolant located in the reservior is bad.
Should find out what that leak is regardless.
Jan 2, 2007 at 9:46 PM
Suggested Repair
Pressure-test the cooling system to identify the passenger-side leak. Keep the existing green coolant rather than mixing it with Dex-Cool. Check whether the orange-red fluid is transmission fluid. A low-coolant light with a full tank is likely a faulty reservoir sensor.
Conversation Summary
The owner of a 1996 Chevrolet Cavalier reported an orange-red leak under the passenger-side coolant tank and a low-coolant light despite a full tank of greenish coolant. The expert said the car originally used orange Dex-Cool, advised staying with the green coolant already installed, and recommended pressure testing to find the leak. Transmission fluid is red, and the light is likely caused by a bad reservoir sensor.
