Chevy Cavalier Radiator Tank Leak Fix
hope this helps.
____________________
I try to answer questions as though it was my car. Always the best way to go.
1997 Chevy Cavalier
Suggested Repair
Replace the radiator rather than repairing the cracked plastic side tank, especially given the very high mileage. A good used radiator may cost about the same as a repair. Drain the coolant into an approved container, disconnect the hoses, remove the electric fan, unbolt the radiator from the A/C condenser, and then unbolt and remove the radiator.
Conversation Summary
The owner of a 1995 Chevrolet Cavalier with a 2.2L engine and very high mileage reported coolant loss from a crack in the radiator's black plastic side tank, without overheating. The expert said a shop could repair that damage but recommended replacement because of the mileage, noting a used radiator might cost about the same. A follow-up asked how to remove the radiator from a 1997 Cavalier, and the expert outlined draining the coolant, disconnecting the hoses, removing the electric fan, and unbolting the radiator from the A/C condenser.
