1993 Chevrolet Cavalier Coolant Leak
KELLYCOOK
93 Chev Cavilier
95,000 miles
2 cyl.
NO weird sounds
I replaced the 2 hoses (Top & Bottom) about 6 months ago. No problems until:
It began leaking radiator fluid but not near the hoses that I replaced, not the radiator nor around the radiator, not the reserve tank and not around the engine.
It is near the fire wall and it is a black hose small shaped like a sideways L. When I put my finger over the hose it stops leaking. It is leaking half of the fluids that I put in and keeping the radiator only half full.
Sould this black hose just have a plug on it or does it inter connect with the flow of the radiator fluid system?
If not plugged than what should it connect into for the fluid to stop leaking?
Jun 29, 2007 at 8:19 AM
E40WATER12
  • 522 POSTS
I would just replace the L shaped hose, Thats should stop youre coolant from leaking. Also has youre cooling system been serviced lately?.
Jul 2, 2007 at 10:07 PM
KELLYCOOK
This hose is a rubber elbow coming out of the fire wall pointing down & no fluid is leaking into the passanger side of the car.
To me it seems like it is missing a plug or a cap on this hose.
I have no air-conditioner in car b/c compressor is blown.
SO should I still have coolant system serviced?
Could this be a heater core issue?
Jul 3, 2007 at 10:25 AM
Suggested Repair
Replace the small L-shaped rubber hose near the firewall that is leaking coolant. If the cooling system has not been serviced recently, have it inspected and serviced as well.
Conversation Summary
A 1993 Chevrolet Cavalier owner reported coolant leaking from a small L-shaped black hose near the firewall, not from the radiator, hoses, reserve tank, or engine. Covering the hose stopped the leak, and the owner wondered whether it needed a plug or connected to the cooling system, and whether a failed heater core or lack of air conditioning was involved. The expert advised replacing the L-shaped hose and asked whether the cooling system had been serviced recently.
