1989 Chevrolet Cavalier Heater Leak
SHANEMSINK
I got a friends car in here working on it......again. I replaced the heater core a few months back, now it appears to be bad again. He says that this is the fourth or fifth heater core he has had to replace.1989 2.2 Any Ideas? I'm stumped
Feb 5, 2007 at 11:42 AM
BOOTDOG
  • 665 POSTS
by bad do you mean it's leaking? when you install it are you making sure that the heater core is properly fitting inside the heater box? because metal on metal can rub a hole in no time, that is if it's leaking again. let me know. i reply as soon as i can
Feb 6, 2007 at 10:04 AM
SHANEMSINK
Turned out to be a worn hose, but he did have to have the heater core replaced a bunch of times. Not surprising with the 2.2 I guess.
Feb 6, 2007 at 12:51 PM
BOOTDOG
  • 665 POSTS
i'm glad it was a simple fix. we're here to help when you need it :D
Feb 7, 2007 at 9:45 AM
Suggested Repair
Replace the worn heater hose. When installing a heater core, confirm it seats properly in the heater box so metal-to-metal contact does not rub a hole.
Conversation Summary
A 1989 Chevrolet Cavalier 2.2 had repeated heater core replacements. The expert asked whether the core was leaking and whether it was fitted correctly in the heater box, noting metal-on-metal contact can wear a hole quickly. The owner later reported the problem was a worn hose.
