1993 Chevy K1500 Fuel Gauge Inaccurate
CHEVROLET
HARDINGRICHAR
I HAVE A 1993 CHEVY K1500 4X4 PICKUP SILVERADO. I HAVE RECENTLY REPLACED THE INSTRUMENT CLUSTER THROUGH THE LOCAL CHEVY DEALERSHIP AND REPLACE EVERYTHING IN THE GAS TANK, CHECKED ALL THE GROUNDS I COULD FIND, BUT MY GAUGE GOESW WAY PASS FULL WHEN I FILL UP AND WILL NOT GO BELOW ABOUT 3/4 OF A TANK WHEN EMPTY AND WAS DOING THIS BEFORE I REPLACED EVERYTHING.
Jan 5, 2007 at 10:30 AM
SERVICE WRITER
  • 9,123 POSTS
I hope you didn't pay to have it diagnosed!
Some of those chevy pick ups have a faulty connector at the pump that needs replacement, this may be one.
Jan 5, 2007 at 12:21 PM
MATHIASO
  • 1,209 POSTS
After you have checked for faulty connector at the pump and still have the same problem, perform this test by disconnecting the fuel-gage wire at the sending unit.Then turn the ignition key to the ON position to provide power to the instrument panel.With the wire unhooked and the key on, look at the fuel gage reading.If the gage is operating properly, it will read either COMPLETELY FULL or COMPLTETLY EMPTY, depending on the make and model of the car.
Next, take the end of the disconnected wire that leads to the fuel gage and connect it to a metal part on the vehicle's frame. This procedure is called" grounding the wire". while the wire is grounded, look at the fuel-gage reading. If the gage is operating properly it should read either COMPLETLY EMPTY or COMPLETLY FULL depending of the make and model of the car.However, the reading should be exactly opposite of the reading you obtained with the wire unhooked.
If the gage responds correctly during this test, the problem is in the sending unit.However ,if the reading is the same, the problem is either in the wiring to the fuel gage or in the fuel gage itself.
Bring your car back to the dealer and have them check the " everything in the tank again". and have them do this test for you.
Jan 6, 2007 at 5:34 AM
Suggested Repair
Inspect and replace the fuel-pump connector if it is faulty. With the key on, disconnect the fuel-gauge wire at the sending unit, then ground that wire to the frame. Opposite full and empty readings indicate a bad sending unit; the same reading points to the wiring or gauge. Have the dealer recheck the in-tank parts and perform this test.
Conversation Summary
The owner of a 1993 Chevrolet K1500 Silverado replaced the instrument cluster and everything in the fuel tank and checked grounds, but the fuel gauge still reads past full when filled and about three-quarters when empty. Experts suggest a faulty pump connector and a sender-wire disconnect and ground test to distinguish a bad sending unit from wiring or gauge problems, followed by a dealer recheck.
