1998 Chevy Blazer Fuel Gauge Not Working
ROYPHILLIPS
I have a 1998 Chevy S10 blazer v6 mileage 125000
I resently replaced the fuel pump now the the fuel gage doesnt work it will only go to just above the red mark enough to make the low fuel light go out,i have to use the trip meter to gage when i need to refuel. what could be causing the fuel gage not to work?
Thank you Roy
Apr 13, 2007 at 3:32 AM
BOOTDOG
  • 665 POSTS
the problem is probably gonna be a defective fuel sending unit on the fuel pump. i hate to say it but you'll need another fuel pump. the sending unit comes on it. i would drive it till you know when it's time to fill up then replace it. before you do, make sure all the connections to the pump are good. if so and the problem still exists, replace the pump and send the other back for a warranty. good luck
Apr 13, 2007 at 8:13 AM
Suggested Repair
Check that all fuel pump connections are secure. If the gauge still stays near empty, the sending unit on the replacement pump is likely defective; replace the pump and return the other unit under warranty.
Conversation Summary
A 1998 Chevy S10 Blazer owner replaced the fuel pump, after which the fuel gauge only rose just above the red mark enough to turn off the low-fuel light. The owner now uses the trip meter to judge when to refuel. The expert said the sending unit on the new pump is probably defective, advised checking the pump connections first, and recommended replacing the pump and returning the other unit for warranty if the connections are good.
