1996 Chevy 1500 Sudden No Power
CHEVROLET
LWAYNE
This afternoon I went out to start my 1996 Chevy 1500, V-8 5.7 engine and after letting it warm up for a few minutes (it is very cold weather) I shifted into drive and started to drive off then everything just died...no power; no electric--nothing. Went out later and have interior dome lights but nothing else. Turn key in ignition and it doesn't do anything.
Jan 14, 2007 at 3:54 PM
SERVICE WRITER
  • 9,123 POSTS
No headlights?
How old is the battery?
Jan 14, 2007 at 9:21 PM
LWAYNE
Battery is 2 months old.
Jan 15, 2007 at 2:11 AM
SERVICE WRITER
  • 9,123 POSTS
If you only have a dim interior light and dim or no headlights, either the battery is a defect or there is a cable loose,defective or dirty connection as I see it. Check at the battery, to the ground, to the starter. There should be no green or corrosion, nothing loose.
Jan 15, 2007 at 2:25 AM
LWAYNE
Loose battery cable. Thanks!
Jan 15, 2007 at 7:15 AM
Suggested Repair
Inspect and secure the battery cables and connections at the battery, ground, and starter. Clean any corrosion and tighten anything loose; a loose battery cable was confirmed as the cause.
Conversation Summary
A 1996 Chevy 1500 with a 5.7 V-8 died while driving in cold weather and then had no electrical power except dim interior lights; the ignition did nothing. The two-month-old battery led the expert to suspect a defective battery or a loose, dirty, or corroded cable at the battery, ground, or starter. The owner later confirmed a loose battery cable.
