1993 Chev 1500 pick up
1993 ALL OTHER MAKES ALL OTHER MODELS
CAT602
  • 6 POSTS
My 1993 Chev 1500 pickup is idling in drive around 610-650 rpms and occasionally stalls. When in park, it idles around 700 rpms and has no problem. How do I raise the rpms so that it no longer stalls in drive, and is this the problem?
May 3, 2006 at 11:03 AM
LOSONE
  • 1,616 POSTS
Is your PU throttle body or port injection??
May 4, 2006 at 9:45 AM
CAT602
  • 6 POSTS
Its throttle body with fuel rails, and checked the compression lines and had no problem there.
May 6, 2006 at 9:07 AM
LOSONE
  • 1,616 POSTS
Remove the idle air valve from the side of the throttle body. Using some carb cleaner, clean the area in the throttle body as well as the module. Remove all the carbon deposits.
Replace it and start the engine. It will run rough for a bit because of the cleaner. Let the engine get warm
Unplug the IAC motor on the side of the throttle body.
Set base idle with the adjusting screw on the side of the throttle body to 400-450 RPM
Shut the engine off
plug the IAC back in and start the engine. Drive it for about 5 miles to reset the computer.
Shut off the engine. Disconnect the neg battery lead for about 15 seconds.
Let the truck idle for a bit and see how the idle settles in.
If this doesn't work you may have to replace the IAC.
NEVER- NEVER adjust the idle screw on the throttle body unless you follow this procedure.
Good luck
May 7, 2006 at 1:30 AM
CAT602
  • 6 POSTS
Thanks a lot, I'll give it a try.
May 7, 2006 at 6:23 AM
CAT602
  • 6 POSTS
I replaced the IAC valve, followed the given directions, and its still stalling. Any other ideas?
May 15, 2006 at 10:56 AM
LOSONE
  • 1,616 POSTS
Sorry I have been away from my computer for a few days. I was off doing a book signing.
I would check the ignition timing. First locate the brown connector located in and around the harness just above the distributer. With the truck off disconnect the "spout". Set up you timing light start the truck and bump the timing up 2 or 3 degrees. I like to see your engine set about 5 degrees BTDC. The 0 setting makes the engine slug a little. The increase will increse idle about 50-75 RPM.
Shut the engine off, disconnect the battery to clear the check engine light and drive it for a couple of miles and see how the idle RPM settles in.
I have also seen a transmission fluid and filter change increase the idle speed. Also what viscosity oil do you use in the engine?
Let me know
May 17, 2006 at 12:49 AM
