1992 Stanza wont idle until warm
  • 1992 ALL OTHER MAKES ALL OTHER MODELS
In cold weather, 40 or less. The car wont idle, you have to rev the engine to about 1000 plus RPM or it will stall. Once she is warmed up she runs fine. I noticed there is a cable that connects to the throttle and goes to a diaphram wich then has a vacume line that goes to a motor on the drivers side fender wall. I tested this motor with a standard test light and it doesnt appear to be getting power. QUESTION: What is this motor and where does it get power from? Does it have anything to do with the symptoms? Please help.
Thursday, January 12th, 2006 AT 3:21 AM
SPEEDSHOT
Sounds like a vacuum leak to me, but not sure, when the engine warms up things expand to close it off. Check for bad hoses, broken connectors, etc. The other thing you describe sounds like your cruise control (if so equipped) Didn't know they had to have power but things change every day
Sunday, June 25th, 2006 AT 3:14 PM
