1990 Chevy 1500 Electrical Drain
CHEVROLET
TRIP3COMMY
1990 Chevy 1500 pickup 137000 miles. Im having some electrical problems. The electrical gauge dips in unison with the blinkers and at night it wavers when I turn the headlights on. I checked the fuse after driving a few miles and it was extremely hot, burning my finger. I got a few "clicks" when I tried starting the other day and now the battery is now dead. I replaced my battery a few months ago. Also, after having changed the battery, my right speaker, which crackled and hissed previously, began working. It has since degraded into crackling again. Any Ideas? Thanks.
Jul 7, 2006 at 9:11 AM
MIKEYBDMAN
  • 623 POSTS
First off, which fuses are getting too hot to touch? That does not sound good, and needs to be corrected before your truck is a burned out shell on the side of the road.
Your problem sounds like one of two things. Either your charging system is not working properly, or is insuffient to run all of the things on your truck.
I know we love to add things to our trucks and make them personal, but let me ask u this. Have you added things like speakers, subwoofers, lights, ect....?
Your charging system is designed to operate all things that came factory standard, and still charge your battery in normal driving conditions. If we add items that use some of the power, there may not be enuff juice left to keep your battery charged.
More than likely you either have a charging problem, (take ur vehicle to advanced, or napa and have them check your charging system). Or, you have something that is shrted and drawing too much current, or a continous current while the switch is off.
Check your battery voltage with the terminals off, and then rehook them and see if the volts are the same with the ignition switch off and all lights off. If you have something drawing current, you will have to use the wiring diagrams and figure out what it is and correct the problem.
Hopefully it will be something as simple as a altenator, or a bad ground.
Always check your ground cable that runs from your battery to the engine block. These corrode and cause a ton of problems.
Jul 7, 2006 at 11:06 AM
TRIP3COMMY
[quote:2fc6f7a177="Mikeybdman"]First off, which fuses are getting too hot to touch? That does not sound good, and needs to be corrected before your truck is a burned out shell on the side of the road.
Always check your ground cable that runs from your battery to the engine block. These corrode and cause a ton of problems.[/quote:2fc6f7a177]
First of all, the fuse that was hot was the big metal one that says battery. Secondly, everything is factory, no add-ons.
Jul 9, 2006 at 6:10 AM
MIKEYBDMAN
  • 623 POSTS
Sounds like your altenator is not keeping your battery charged. I would charge the battery and then have napa or advance check the charging system for a bad altenator. Also make sure you check the ground cable from the battery to the engine block.
Good luck, and let us know what it was....
Jul 9, 2006 at 6:40 AM
TRIP3COMMY
Turns out it was a short in the passenger door wiring that fried my battery etc
thanks for the help
Aug 30, 2006 at 3:56 PM
Suggested Repair
Repair the short in the passenger door wiring. Then charge and test the battery and charging system, inspect the battery-to-engine ground cable, and replace the overheated battery fuse if damaged.
Conversation Summary
A 1990 Chevy 1500 had gauges that dipped with the turn signals and headlights, an extremely hot battery fuse, slow cranking, and a dead battery despite a recent replacement. A speaker that briefly improved after the battery change later crackled again. The expert suspected a weak charging system, a bad ground, or an excessive current draw and recommended a charging-system test and ground inspection. The owner later confirmed a short in the passenger door wiring had damaged the battery.
