1998 Chevrolet Cavalier Coolant Leak
CHEVROLET
MUSICMAN_20012003
1998 chevy cavalier, mileage 122000. I have a coolant leak somewhere and i am not sure where it is coming from, one person has told me freeze plugs another the head gasket, and another told me about a thing called a "weep hole" in the pump itself....now i know its not the head cuz i just changed my oil and nothing wrong, there are none of those 'tell tail signs' or anything else, can someone give me some advice?
May 9, 2006 at 6:51 PM
LOSONE
  • 1,616 POSTS
Have the system pressurized by a mechanic. The leak will become very evident. If it comming out of the "weep hole" that indicates a bad water pump as they are designed to do that. Good luck
May 10, 2006 at 1:45 AM
OLEY422
I am actually having this same problem in my 99 Chevy Malibu. HOw common is this problem?? I have to refill the coolant about once a week, but we cannot find a leak anywhere...we're not really sure where the coolant is going. In addition to this, my AC light flickers on and off along with the AC fairly frequently. I'm not really sure what to do about it...I'm leaving for school in three weeks and don't know whether I should get it fixed before then, or how to go about getting it fixed since I'm not really sure what's wrong with it. Any suggestions?
Jul 24, 2006 at 1:29 PM
Suggested Repair
Have a mechanic pressure-test the cooling system so the leak location becomes obvious. If coolant is coming from the water pump weep hole, replace the water pump.
Conversation Summary
The owner of a 1998 Chevrolet Cavalier with 122,000 miles reports an unidentified coolant leak and has been told it could be freeze plugs, a head gasket, or the water pump weep hole. They do not think it is the head gasket because a recent oil change showed no contamination or other typical signs. An expert recommends pressurizing the cooling system to reveal the leak and says coolant from the weep hole indicates a failed water pump. A second owner mentions a 1999 Chevrolet Malibu losing coolant weekly with no visible leak and a flickering AC light, but no diagnosis was given for that car.
