Your brake squeeler is set to start scraping the disk or drum about 1/4 of an inch before the rivets in the pads start to grind and do damage. It sounds as if you need to replace the rear brakes also.
Follow the manual and the rear brakes will be easy also.
SPONSORED LINKS
Saturday, July 8th, 2006 AT 4:29 PM
