1997 Chevy 1500 Backfires on Decel
CHEVROLET
THE_HYDROXIDE_CHILD
  • 82 POSTS
My Aunt Has a 1997 Chevy Pickup 1500 it has 183K miles and i think it has a 350 5.7L whenever accelerating the truck is fine but when cruising and you deaccelerate it backpops and jumps a lot then the check engine light will start flashing and eventually stay on the codes were multiple cylinder misfire and the o2 sensor but we got a nasty egg smell and i was think would the converter do this??? or what do it sound like....
Feb 20, 2007 at 7:24 AM
CHEVY22
  • 1,375 POSTS
well , i will answer loosely on this ,
if i read this right , first you had the misfires and the 02 code and then the egg smell,
if so one or more of the 02 sensors went bad creating the random misfire ,probably dumping raw fuel into the converter melting it inside,
replace the 02 that came up bad , check normal tune up item sand replace if needed, and reset pcm, you may need a converter but start with what you know is wrong
Feb 20, 2007 at 7:46 AM
Suggested Repair
Replace the oxygen sensor that set a code, inspect and replace needed tune-up parts, and reset the PCM. A catalytic converter may also be needed if raw fuel from the misfires damaged it, but start with the confirmed faults.
Conversation Summary
A 1997 Chevy Pickup 1500 with about 183,000 miles runs fine while accelerating but backfires and jumps when decelerating from cruise. The check engine light flashes and then stays on, with multiple-cylinder misfire and oxygen-sensor codes, plus a rotten-egg smell. The expert says a failed oxygen sensor likely caused the misfires and sent raw fuel into the converter, possibly melting it. The suggested first steps are to replace the bad oxygen sensor, check tune-up items, and reset the PCM before deciding on a converter.
