1993 Chevrolet Truck Backfires on Start
Make sure all hoses are routed right.
Make sure all hoses are routed right.[/quote]
Ok. I have replaced the gaskets around the throttle body and double checked the placement of the hoses. All seem good. I started it last night with some success but when I let it stand for a few minutes and came back to start it again the backfiring returned. Any thoughts?
If it's reading high check the pcv hose first to see if it's clogged.
Thanks for the help. I know now that to be exact is most important.
Suggested Repair
Check for a vacuum leak at the intake or throttle body and confirm all vacuum hoses, including the PCV hose, are routed correctly and not clogged. Also verify distributor installation: the gear alignment marks and number-one plug-wire position must match the engine, because being off even one tooth can cause throttle-body backfire.
Conversation Summary
After replacing the intake manifold on a 1993 Chevrolet half-ton truck with a 4.3L, the engine cranked, backfired through the throttle body, and blew off the PCV vacuum hose under throttle. An expert suggested a vacuum leak around the intake or throttle body, incorrect hose routing, and a clogged PCV hose if oil pressure was high. The owner confirmed the gaskets and hoses were good, then found the distributor was misaligned. Aligning the distributor gear with the available case marks and pointing the number-one plug wire toward the front of the vehicle eliminated the backfire and restored normal running.
