1982 Chevy Blazer Backfire on Decel
82BLZRMAN
'82 Chevy K-blazer 350cid v8 4speed manual trans.
100k miles
Mods: headers/duel exhaust/MSD ignition/edelbrock intake-nonEGR
Problem: idles fine, accels fine, backfire when decel in gear
Jul 6, 2007 at 1:05 AM
MERLIN2021
  • 17,250 POSTS
2 things will cuase it. 1.) Vacuum or mechanical advance not working.
2.) If you still have converters with air tubes and check valve on the manifild, one of the check valvles is NG, air tube has holes...
Jul 6, 2007 at 8:48 AM
Suggested Repair
Check that vacuum and mechanical ignition advance are working. If catalytic converters with air tubes and a manifold check valve are still installed, inspect the check valves and air tubes for a failed valve or holes in a tube.
Conversation Summary
An owner of a 1982 Chevy K-Blazer with a 350 V8 and manual transmission reports a backfire only during deceleration in gear; idle and acceleration are fine. The vehicle has headers, dual exhaust, MSD ignition, and a non-EGR Edelbrock intake. The expert says the cause is likely failed vacuum or mechanical advance, or a bad air-injection check valve or holed air tube if converters and air tubes remain.
