1997 Chevy Blazer small backfire??
BUB74
Engine Performance problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic
if the ignition switch is bad the car will not start correct? and when i try to start car and let off of the key i notice like a small backfire or maybe some back pressure? i dont know is that normal when ignition swith goes bad?
Feb 23, 2010 at 12:05 AM
  • 110,248 POSTS
An ignition switch can cause the engine not to start. When you turn the key in, do the dash lights come on?
Feb 24, 2010 at 2:15 AM
BUB74
yeah they did. strange thing is the car sat for a day and i tried to strat it and it started rite up?? crazzy car
Mar 20, 2010 at 7:35 AM
  • 110,248 POSTS
That sounds like a typical car. As soon as it gets to a mechanic, everything seems to get better.
If you have futher problems, let me know. Just use this same thread.
Mar 20, 2010 at 6:04 PM
