Engine Mechanical problem
1993 Other Chevrolet Models 6 cyl Two Wheel Drive Automatic 15k miles
if the motor is spitting back into the caborator could this be the timing
Thursday, February 26th, 2009 AT 4:15 PM
BOGONE
MEMBER
Is it a constant pop, pop, pop, pop, pop. Or isit a hesitation pop when you open the throttle? If it is a constant pop it is likely that it has jumped cam timing or burnt an valve. If it is a hesitation pop there is alot of things that would cause that.
