SKETTY20
99 monte carlo 130,000 3.1 v6
as u know the ball joint is on the bottom of the.... thing that holds on the caliper and rotor. the rivets are on the bottom with hardly no access to the top of them. ive knocked off the the bottom but there is little room to hammer and punch it out. long story short outta ideas to get the ball joint off. help!!!!!
mike
Sep 17, 2007 at 9:20 AM
MERLIN2021
  • 17,250 POSTS
If you have an air compressor, use an air chisel to clean up the ens, then a punch to drive the nubs out...joint will fall right off.
Sep 17, 2007 at 9:53 AM
