2002 Chevy Monte Carlo rear suspension
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANNYROJAS27
I ran over a pot hole and now it feels like my car is rolling on a oval wheel. I checked the rim and wheel and they seem to be fine. Could it be the strut
Dec 30, 2009 at 3:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
may have broken a belt in the tire that is not visible by the untrained eye. if tires are for sure good then would more likely be a ball joint failure than a strut failure. only way to know is to remove the wheel and tire assembly and inspect visually the suspension on the concerned area.
Dec 30, 2009 at 4:24 PM
