Hodo I replace a bent rear sway bar and will that help keep my front tires from wearing away
Sunday, July 12th, 2009 AT 8:19 PM
MECHANIC
Has the front end been aligned? The rear sway bar shouldn't cause too much tire wear on the front. As far as replacement, there are (i believe) 4 mounting locations. They sway bar just unbolts from those spots. You may want to replace the rubber bushings while you have it apart.
