1997 Chevy Monte Carlo Brake lights
CHUPACHAM
  • 1997 CHEVROLET MONTE CARLO
Brakes problem
1997 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic 112ooo miles
Regular brake lights won't work, brake light on rear window works. I replaced the bulbs and the fuse looks fine. Also the brake light switch works. Please help.
Saturday, February 13th, 2010 AT 12:03 PM
JDL
  • 16,098 POSTS
Hi, do the turn signals work? Your lower brake lites are wired through the multifunction switch. Possible issue with multifunction switch?
Did you check for voltage and ground at the rear lamp. Green wire on one side, yellow on the other for voltage. Black is ground.
Saturday, February 13th, 2010 AT 12:20 PM
CHUPACHAM
Think I`have a fualty switch, but thank you!
Saturday, February 13th, 2010 AT 12:51 PM
HAZEE
I had the same problem with my 99 model. I would notice that the brake lights would work when I pulled the turn signal towards me (but not turning on your brights) when braking, but not if I left the turn signal alone. It's a wiring issue with the vehicle's steering wheel column and not uncommon to monte carlos at all. I had to replace the turn signal and have the wiring in the steering column fixed after I failed my vehicle inspection.
Tuesday, February 16th, 2010 AT 1:52 PM
