Why is my engine overheating?
NORCAL
  • 23 POSTS
  • 2001 CHEVROLET MALIBU
  • 85,000 MILES
Friends 2001 Chevy Malibu was overheating and was driven on into the red. I replaced the thermostat for her hoping for no further damage however upon restart and drive the car now blows white smoke, runs rough as if a piston misfiring, and still overheats. I'm thinking HG, warped head, cracked IM, or cracked block etc. I just need to know what you think? Most of all is how to diagnose correctly. Thank you in advance.
Wednesday, October 28th, 2020 AT 5:50 PM (Merged)
NORCAL
  • 23 POSTS
I guess I should have just gone to troubleshooting first lol. I found the main reasons and ways to check. If there are more tips or tricks that can help please post em thanks
SATURNTECH9
  • 30,869 POSTS
Rent a chemical block tester from auto zone buy the fluid and that will tell you if have a blown head gasket etc wont tell you which it is. You will have to tear it apart to figure that one out.
NORCAL
  • 23 POSTS
Thanks saturn. Looks like no matter what though it's gonna be a project. Wish me luck
SATURNTECH9
  • 30,869 POSTS
Wish you luck please keep me posted.
MICHAEL BRANDON RACK
  • 6 CYL
  • FWD
  • 122,000 MILES
I have a 2001 chevy malibu. It has been getting hot whenever I am stopped but while on highway the temp goes down.I thought it could be water pump but when I turn the engine off, water leaks onto the ground from driver side next to where the wheel is it seems. What do I need to replace most likely or where can the water be leaking from?
ERNEST CLARK
  • 1,730 POSTS
There's more than one possible cause. Also, is the coolant coming from the overflow tank onto the ground? If so, that's a normal place for it to leak when it's too hot. Rather it come out there than somewhere else.
You should first check that the radiator fans are coming on. They're meant to push air through the radiator when the car is sitting still. While driving, the air coming through the grill is enough to cool the radiator by itself. If the fans aren't coming on, first check the relays. If they're good, check wiring/connectors/temp switch and fans themselves.
BLACKCLOUD508
Engine Cooling problem
2001 Chevy Malibu 6 cyl Front Wheel Drive 85'000 miles
car overheated and lost power as I tried to pull over. Now won't start, but sometimes have lights, bell, etc. Battery only clicks. Appears to be antifreeze under(on?)Engine driver's side. Did I burn it up?
SAVOYSTYLES
Looks like what you have here is a blown head gasket. The loss of power/ability to start is due to the lack of compression. With a little luck, it may just be a gasket replacement ($600 +), but residule problems can become evident once the head is off. A warped or a cracked head can occur when the engine has been overheated. A warped head usually can be machined/repaired by a qualified machine shop, while a cracked head will need to be replaced.
Next question you have to ask is what is the root cause of the engine overheating. You may be looking at replacing your waterpump, hoses, heater core. Etc. All in all. This is usually a good size job for the shady tree mechanic (at least a weekend to replace the head gasket). Good luck. Hope things work out in your favor
BAWITHEBA
  • 5 POSTS
  • 6 CYL
  • FWD
  • 154,000 MILES
Ok this is my problem
I bought the car and 3 days after I purchaced it the car got hot. The fans were not running so hey its a easy fix. Changed the relay and vola it works. But then it kep getting hot. So I hard wired the fans to come on with the turn of the key. It still got hot. I replaced the water resivor cause it didnt seam to hold the pressure of the system. I also changed the thermostat it still got hot. I completly gutted the thermostat so it would have the seal still. So basically there is no thermostat now. It still gets hot. But it takes a while like 30-40 miles or more some times. It is like a ghost sometimes its ok then other times its not. I dont know if it is the radiatior or maybe the catalic converter. Please help me.
BLUELIGHTNIN6
  • 16,542 POSTS
Check for coolant mixing with the engine oil and vice versa. These malibus often have head gasket failures which can result in overheating.
BAWITHEBA
  • 5 POSTS
Ok I forgot to mention that. I read that online and my engine oil is clean no water. And with the new tank I can tell that the coolant is clean too. When the last time it went to a mechanic he checked for a head gasket problem he said it was in good condition. The problem was that while he had it there running it never got hot. And he didnt know what to do about it.
BLUELIGHTNIN6
  • 16,542 POSTS
Does it seem to overheat moreso in heavy traffic/slow moving or on interstates /higher speeds? Are there any actual signs of overheating besides the gauge? It may simply be a faulty engine coolant temp. Sensor which is sending inaccurate reading to the gauge.
BAWITHEBA
  • 5 POSTS
It seams more in faster moving it seams to actually cool in slow traffic. The guage was actually faulty so it has a external temp guage. Non electronic just a simple guage hardwired in. And yes when it is hot it has steam comming from the bleeder valves when I open them.
BLUELIGHTNIN6
  • 16,542 POSTS
Should have radiator flushed and checked. Slow speeds the fan can keep it cool enough, higher speeds it depends more on radiator and coolant flow, if rad. Is partially clogged it will cause restricited coolant flow
BAWITHEBA
  • 5 POSTS
Thank you it is going to the shop tomorrow and im gonna discuss it with him hopfully it is the radiator and I can get it changed and be on my way. So what do you think about it being the catalic converter?
BLUELIGHTNIN6
  • 16,542 POSTS
A bad catalytic converter can make a car overheat by causing a backup of pressure in the cylinder head so you may want to have it flow tested as well
BAWITHEBA
  • 5 POSTS
Thank you hopefully this will help with my problems
TERRYCAMP
  • 6 CYL
  • FWD
  • 116,000 MILES
My car overheats out of the overflow. The head gasket has been change, the level is were it should be. There is all kinds of heat, when I turn on the heater.I'm not really sure if the fans are working the way they are suppose to.
Wednesday, October 28th, 2020 AT 5:51 PM (Merged)
MIKE H R
  • 3,094 POSTS
Most common problem with a vehicle overheating is the thermastat or a clogged system. When you drive the car at higher speeds than stop and go does the temp guage go down to normal. If so then the problem could be in the fans. If it goes down a little but still on the high side then I would change the thermastat and have system cleaned out.
Related Engine Overheat Content
